anhloc's avatar
anhloc
>4TB Support For NV+ V2
Any chance the ReadyNAS NV+ V2 will be updated to support >4TB drives, or has Netgear limited that to their new NAS series?
  • I notice that the WD red 6TB are on the HCL for the RN314/312. Are they likely to be supported in the RN104/102...that would be a great boost to those devices!
    Martin
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Hi Martin,
    I will ask our QA team about that.
    Thanks
  • Cheers! Hopefully its a yes although I doubt I will fill my RN104 in a very long time! It has to be good for Netgear's readynas marketing though
  • mdgm wrote:
    You may find that larger capacity drives work for you, but we haven't qualified drives larger than 4TB in capacity for the NV+ v2.
    You should stick to our compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641
    I'm aware of that. I figured that since NetGear has tested the WD60EFRX drives in newer ReadyNAS models, that my 1.5 year old NV+ V2 would still be able to use the newer drives, or that NetGear would take the time to test that out.
ProSupport for Business
