MaximG
Feb 22, 2012Aspirant
512Mb/1Gb DDR3 for ReadyNAS Duo v2
Hello, I think to upgrade from my old ReadyNAS Duo to ReadyNAS Duo v2. I searched extensively for a compatible 512Mb or 1Gb DDR3 for new ReadyNAS DUO. Can anyone help me?
PapaBear1
Feb 22, 2012Apprentice
MaximG - Not at this time. They have hinted that it may be ported to the x-86 units in the future but have not stated so definitely. They have basically said it will NOT be ported to the Sparc based units (Duo v1/NV+ v1). The numbering (5.3.x) on the ARM based units leaves room for it on the x-86 (currently 4.2.x).
Be advised that the Duo v2 lacks many features found on the Ultra 2. For two, it does not currently support NFS, although there are hints that it may come in the future, and it does not support rsync (no hint about the future). Many 3rd party add ons for the x-86 units will not run on the ARM based units. If you plan on keeping the Duo, with the Ultra 2, you could set it up to automatically back up on a schedule to the Duo via rsync. (Yes the Duo v1 supports both NFS and rsync). The first backup should be done with NFS and then switched to rsync for each subsequent backup. It basically synchronizes the files by share between the two units. (My backup jobs run every night).
