TeknoJnky
Oct 30, 2017Hero
528x ram/memory upgrades
I am looking to upgrade the ram in my 528x, currently with the stock 4g. Has anyone upgraded theirs yet? Is there a list of compatible ram or details/specifics somewhere? also considering upgrade ...
- Oct 30, 2017
The 600 series can use a higher speed RAM than the 500 series
RN526X/RN528X: 4 memory slots (Max: 64GB), support up to DDR4-1866
RN626X/RN628X: 4 memory slots (Max: 64GB), support up to DDR4-2133We don’t support upgrading the RAM. You do so at your own risk. Be sure to run the memory test after replacing the RAM.
mdgm-ntgr
Oct 30, 2017NETGEAR Employee Retired
- TeknoJnkyOct 30, 2017Hero
Thanks for the reply!
does either 528x or 628x come with, and/or support ECC ram?
- mdgm-ntgrOct 30, 2017NETGEAR Employee Retired
Yes they come with ECC RAM and that’s what you should use if you do decide to replace the RAM.
Very strange, I spent a few minutes googling and keep seeing something like this example:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820326400
This shows both ddr4 *and* ddr3 ?!?!
16GB 288-Pin DDR4 SDRAM ECC Registered DDR3 1866 (PC3 14900)
I can't seem to find anything that has ddr4-1866 / PC4-14900
for other's future reference, I found some additional info on my specific device:
hwinfo
Memory Device: #73 Location: "DIMM_A1" Bank: "NODE 1" Manufacturer: "Undefined" Serial: "00142A3C" Asset Tag: "DIMM_A1_AssetTag" Part Number: "TS512MLH72V1H" Memory Array: #71 Form Factor: 0x09 (DIMM) Type: 0x1a (Other) Type Detail: 0x0080 (Synchronous) Data Width: 72 bits Size: 4 GB Speed: 2133 MHzdmidecode
Handle 0x0047, DMI type 16, 23 bytes Physical Memory Array Location: System Board Or Motherboard Use: System Memory Error Correction Type: Multi-bit ECC Maximum Capacity: 128 GB Error Information Handle: Not Provided Number Of Devices: 4 Handle 0x0048, DMI type 19, 31 bytes Memory Array Mapped Address Starting Address: 0x00000000000 Ending Address: 0x000FFFFFFFF Range Size: 4 GB Physical Array Handle: 0x0047 Partition Width: 1 Handle 0x0049, DMI type 17, 40 bytes Memory Device Array Handle: 0x0047 Error Information Handle: Not Provided Total Width: 72 bits Data Width: 72 bits Size: 4096 MB Form Factor: DIMM Set: None Locator: DIMM_A1 Bank Locator: NODE 1 Type: <OUT OF SPEC> Type Detail: Synchronous Speed: 2133 MHz Manufacturer: Undefined Serial Number: 00142A3C Asset Tag: DIMM_A1_AssetTag Part Number: TS512MLH72V1H Rank: 1 Configured Clock Speed: 1866 MHz Minimum voltage: Unknown Maximum voltage: Unknown Configured voltage: 0.003 V
I googled the part # TS512MLH72V1H and got https://us.transcend-info.com/Embedded/Products/No-688
which handily shows the specs and part #'s for other sizes too
Now, trying to find those in stock somewhere for a reasonable price..
