Jan 11, 2019Guru - Experienced User
6.9.5 GPL not posted.
OOM-9
https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL has a link to 6.9.5 GPL, but the zip itself hasn't been posted yet. https://www.downloads.netgear.com/files/GPL/R...
- Jan 17, 2019
Hi StephenB,
The 6.9.5 GPL zip file has been posted already. You should now be able to download the file.
WhoCares_
Feb 04, 2019Mentor
Looks like the kernel .config for x86_64 (didn't test ARM yet) contained in the 6.9.5 GPL archive is broken. At least I'm unable to even run a simple "make clean && make && sudo make modules_install" and get the modules compiled to load into the running kernel. They'll all abort with "Exec format error". It would be great if a fixed .config could be posted or the GPL archive updated with a working .config file ;)
-Stefan
Feb 04, 2019Guru - Experienced User
I'm seeing one other poster saying this also. JohnCM_S - can you escalate?
- JohnCM_SFeb 05, 2019NETGEAR Employee Retired
I will forward this to the appropriate team and will provide you an update as soon as possible.
- CampusFeb 07, 2019Luminary
I did run into the same issue when compiling:
vboxdrv: disagrees about version of symbol module_layout
Any news when this will be fixed?
Thanks.
