Jan 11, 2019Guru - Experienced User
6.9.5 GPL not posted.
OOM-9
https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL has a link to 6.9.5 GPL, but the zip itself hasn't been posted yet. https://www.downloads.netgear.com/files/GPL/R...
- Jan 17, 2019
Hi StephenB,
The 6.9.5 GPL zip file has been posted already. You should now be able to download the file.
WhoCares_
Feb 04, 2019Mentor
Looks like the kernel .config for x86_64 (didn't test ARM yet) contained in the 6.9.5 GPL archive is broken. At least I'm unable to even run a simple "make clean && make && sudo make modules_install" and get the modules compiled to load into the running kernel. They'll all abort with "Exec format error". It would be great if a fixed .config could be posted or the GPL archive updated with a working .config file ;)
-Stefan
itachi2
Feb 18, 2019Tutor
Same here. I tried to use the generic kernel sources from kernel.org but had the same effect, which would lead me to agree that either it is the .config file that is incorrect, or the kernel is not actually the version reported in uname. I also tried the .config files from 6.9.3 and 6.9.4 but had no better luck with either set of sources, so I'm at a loss to determine exactly what's wrong with the sources. I rolled back to 6.9.4 and accompanying source and Virtualbox drivers compiled fine.
Hoping for a good source archive for 6.10 or a fixed 6.9.5 if possible.
- WhoCares_Feb 18, 2019Mentor
I'm in contact with NTGR. What they told me is:
* Due to a change in their build environment the kernels shipping with the firmware 6.9.5 and newer are no longer compatible with modules you build from the GPL sourcces
* The suggested workaround is to not only install the modules but also the kernel as well. I tested this and it works but I don't really like it
* Thanks to NTGR I received a copy of their new build env and I'll see whether I can make that one work again for general usage
I'll keep you posted on my progress.
-Stefan
- gdeguillebonFeb 18, 2019Star
Hi WhoCares_
Thanks for your feedback !
Can you share the command to install the kernel ?
make install does not seem to be enough (this is done in Virtual Machine ReadyNAS)
make install sh ./arch/x86/boot/install.sh 4.4.157.x86_64.1 arch/x86/boot/bzImage \ System.map "/boot" Cannot find LILO.Thanks
- CampusFeb 18, 2019Luminary
Hi All,
I got the same message from NTGR as Stefan did. I haven't tried the kernel replacement yet because it can brick the device and that'st too dangerous for my taste for a production device. If Stefan cannot figure out how to avoid this I will have to keep all my RN716 boxes on 6.9.4.
Hello,
can you share the command to install the Kernel ?
"make install" is it enaugh ?
Unfortunately it isn't as easy as a simple "make install". Basically you'd need to make the normally invisible USB flash drive (that's where the kernel of the ReadyNAS is stored) accessible from the OS. Then you have to manually copy the newly built kernel over the original one, adjust some checksums, then unmount the flash drive, reboot and pray that it works - otherwise you may have either to recover from USB or even have bricked your NAS.
That's also why you'd have to take utmost care when building the kernel. A good idea would be to NOT have anything built right into the kernel but using modules wherever possible. But even then you're not 100% safe since some modules silently enable other kernel settings which as a result may leave you with a disfunctional kernel.
In essence: To prevent users without the proper knowledge from accidentially bricking their system by trying things they don't fully understand I won't post a list of commands here. I'd rather prefer to make the new environment work so everyone can safely build kernel modules without the risk of creating a 2-6 disk paperweight.
-Stefan
