Jan 11, 2019Guru - Experienced User
6.9.5 GPL not posted.
OOM-9
https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL has a link to 6.9.5 GPL, but the zip itself hasn't been posted yet. https://www.downloads.netgear.com/files/GPL/R...
- Jan 17, 2019
Hi StephenB,
The 6.9.5 GPL zip file has been posted already. You should now be able to download the file.
itachi2
Feb 18, 2019Tutor
Same here. I tried to use the generic kernel sources from kernel.org but had the same effect, which would lead me to agree that either it is the .config file that is incorrect, or the kernel is not actually the version reported in uname. I also tried the .config files from 6.9.3 and 6.9.4 but had no better luck with either set of sources, so I'm at a loss to determine exactly what's wrong with the sources. I rolled back to 6.9.4 and accompanying source and Virtualbox drivers compiled fine.
Hoping for a good source archive for 6.10 or a fixed 6.9.5 if possible.
WhoCares_
Feb 18, 2019Mentor
I'm in contact with NTGR. What they told me is:
* Due to a change in their build environment the kernels shipping with the firmware 6.9.5 and newer are no longer compatible with modules you build from the GPL sourcces
* The suggested workaround is to not only install the modules but also the kernel as well. I tested this and it works but I don't really like it
* Thanks to NTGR I received a copy of their new build env and I'll see whether I can make that one work again for general usage
I'll keep you posted on my progress.
-Stefan
