RNASguy
Sep 20, 2023Luminary
6001010060 Communication Error
This is a ReadyNAS 516, running OS6 6.10.8
The NAS box is performing just fine on our LAN
It is configured on the router to have full WAN access based on MAC address
All work stations have full internet access and work fine.
And, I have no issue accessing the admin web interface
However, on my periodic check for an OS update I received a NEW error message:
Check your internet connection, DNS Settings, or proxy settings
Well there is no proxy and access to the internet is just fine.
Any ideas!
thanks
bc
Check your internet connection, DNS Settings, or proxy settingsWell there is no proxy and access to the internet is just fine.
Any ideas!
It's a problem on Netgear's end - the last time something like this happened it was a problem with DNS.
You can install 6.10.9 manually.
- dcheitelAspirant
and how do we get it resolved if its happening now? im trying to update from 6.2.5 to 6.5.2 and then beyond and getting the error.
