qth's avatar
qth
Follower
Feb 14, 2017
A big thing,please help me
  My devces is ReadyNas RND4000 that is premierest one of readynas.Its power adapotor had broken since 2 days ago. I can't find a repleacement in my contury.Would everybody give me any idea? thanks
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello qth,
    You are from China? I don't think support can give or sell you a replacement for the power supply when you are from China.  You might want to check online sellers such as Amazon, Ebay, etc. The part number is RND4PSU1-10000S. By the way, this is for ReadyNAS NV+ v1.
    Welcome to the community!
  • Do a search on "legacy power supply" and you'll find a post from me on adapting a Flex ATX supply to a Legacy 4-bay unit (including your NV+).
    One caution not listed there because it was closed before I reliazed such supplies existed:  Do not get a supply with two separate 12V busses.  You cannot reliably just tie them together to add their capacity.
