iau
Dec 29, 2011Aspirant
Ability to use 3TB disks on ReadyNas Duo
Hi, I have a ReadyNas Duo with 2TB that are quickly filling up. I have been hoping that it would be possible to use 3TB disks when they get more common, but it doesn't seem so. Is the problem with ...
PapaBear1
Dec 29, 2011Apprentice
While StephenB addressed the drives formatted in the ARM units, the same applies to the Sparc units. The Sparc units drive format is incompatible with both the x-86 and ARM formatting. You would have to either start the new unit with at least one drive and copy the data over the network. You might want to consider keeping both the Duo and the drives intact. After you set up the new unit with larger drives and move all your data over, you could then set the Duo up to automatically back up part of the new unit that contains important and critical files.
