iau
Dec 29, 2011Aspirant
Ability to use 3TB disks on ReadyNas Duo
Hi, I have a ReadyNas Duo with 2TB that are quickly filling up. I have been hoping that it would be possible to use 3TB disks when they get more common, but it doesn't seem so. Is the problem with ...
iau
Dec 30, 2011Aspirant
Thanks for your replies. Yes, I will keep the Duo and find some use for it. Always in need of an extra backup! I'll mainly be using it for a home network to access data like pictures that are stored on the server. Will the Pro offer any advantages over the Ultra for this? Noise and temperature are my main concern. I'll have to do some research in one of the other forums for this, I guess, so thanks again.
