Lesmanynunez
Apr 09, 2020Aspirant
Access ready nas via the web using active directoy
Good afteernoon i have setup a rady nas on my networkk using active directoy mapped drives, persmissions are flawless, i am wondering if i cant still enable the access via the web with ready cloud wh...
Sandshark
Apr 13, 2020Sensei
A VPN is an alternative for remote access with A/D enabled (though I've not got A/D myself). I personally like ZeroTier, but there are others, including those that run in your router instead of the NAS.
Lesmanynunez
Apr 13, 2020Aspirant
Well since is a temporary solucion i connected everyone via splashtop for the time been, once in the domain they will need to authenticate and access the folders from there. i tried setting it up with AD in the portal and is a no go. thus splashtop solution. thank you guys for the assit
