readynas12
Aug 08, 2019Aspirant
access readynas discs outwith the unit
I have an older silver ready NAS, the power pack has blown up twice and i have un backed up data i need to get of urgently, can anyone help - can i connect these drives to a PC and access, have trie...
Marc_V
Aug 08, 2019NETGEAR Employee Retired
Welcome to the Community!
What is the model of your ReadyNAS?
If you want to recover your data from your disks, you may want to try using ReCLAIMe and see if it can help you with it, There are also other software being used by the members here so they might be able to add a suggestion.
HTH
Regards
