WallyZ21
Apr 09, 2015Aspirant
Access ReadyNAS RNDU2000 mirrored drive directly from Linux.
Also posted in Ubuntu Forum (http://ubuntuforums.org/showthread.php?t=2272848) ---------------------------------------------- Drive is one from a mirrored pair out of a ReadyNAS RNDU2000 (2 drive un...
mdgm-ntgr
Apr 15, 2015NETGEAR Employee Retired
It uses that "weird RAID 5 setup" to enable expansion from 2 disks to 3 in systems that support that.
It sounds like you should try a different USB to SATA adapter or better yet connect the disks to internal SATA ports and boot off a Linux Live CD
