nikbra
Oct 02, 2016Aspirant
Accessing shares
Hi My NAS is from 2014 and I have been struggling a bit. Got it working but cannot remember how. Also lost the installation DVD. Recently changed computer to a Surface 4 Pro and are trying to acces...
- Oct 03, 2016
nikbra wrote:
Upgrade done. I can mount now. Thanks.
C:\Users\nikla>net use t: \\ip-address\c /user:admin nasadminpassword
Systemfel 53 har uppstått. (eng. Error 53 has occured)Nätverkssökvägen kan inte hittas (eng. Path cannot be found)
Looks like you didn't substitute the real IP address and admin password for the placeholders in italics.
However, if you can mount now, then the test isn't needed.
Oct 02, 2016Guru - Experienced User
Your firmware is pretty old (current version is 4.2.30). After you get this resolved, perhaps upgrade it.
Is the Pro set to the same workgroup as the NAS?
Try opening CMD on the surface, and entering
net use * /delete
Be careful with the slashes (and the typing in general). The first command deletes any outstanding sessions, the second mounts the C volume as drive letter t.
Let us know the result.
nikbra
Oct 03, 2016Aspirant
Hi
Thanks for reply.
The mysterious log out issue remains. It still prompts me for password when logging out. Enter admin by <ip-adress>/admin.
I can also enter the RAIDator by double clicking the Media unit icon. Then I do not need pw. However when chosing a tab in Network I get prompted. Below is the results from the CMD (Swedish):
C:\Users\nikla>net use * /delete
Listan är tom. (eng. List is empty)
BR
Niklas
