jimk1963
Jul 20, 2019Virtuoso
Add SSD drive(s) to RN528X
My RN528x is configured with 8x4TB Toshiba HDD's. Product arrived preconfigured with X-RAID, which chose a RAID 6 configuration. System reports about 21TB usable out of 32TB. I've only loaded up 2TB ...
adorso87
Jul 24, 2019Tutor
jimk1963 wrote:4) RN528x motherboard contains an SSD slot on its backside, unpopulated. I wonder - if I populated that slot wth the m.2 SATA III SSD, would the motherboard use that SSD as cache? Or would it just be ignored? I'm no Linux expert, so if the answer has to do with some kind of invasive OS inspection, it might be over my head
I have an RN524X, I pulled the back panel off and sure enough I found an unpopulated M.2 connector and an unused PCI-e X4 slot. I populated the M.2 with an Intel 660p nvme and booted the machine back up. After getting into the backend of the unit I clicked on every tab, every link, on every page and could not find the nvme drive anywhere. I would say that the M.2 slot is for a wifi connection, a way for your phone to connect to it with better range than bluetooth. As for the PCI-e slot I would say it's for future proofing the unit and cannot be accessed just yet. This was checked on the 6.10.1 firmware. I attached photos of backside of the board these features are on the RN524X, RN526X and the RN528X. Netgear what are they for!?
Sandshark
Jul 25, 2019Sensei
Did you try looking for the SSD via SSH?
Are you saying there is another PCI slot that's not for the 10GBE? I know older NAS like the RN516 have one that's for that (when the board is configured for an RN716x). I doubt is is somehow "deactivated", but you likely would need a riser card to use it.
