powellandy1's avatar
powellandy1
Virtuoso
Aug 21, 2020
Add SSD to RN528X
Hi
Following on from https://community.netgear.com/t5/New-ReadyNAS-Users-General/Add-SSD-drive-s-to-RN528X/td-p/1776859
I've just had a go at adding an M2 SSD to my new 528X. It seems have worked!!
I purchased a TS120GMTS420S from Amazon (£28.46). Installed it in the M2 slot on the back of the motherboard (convenient cut out although I had taken the MB out to add 16GB RAM as well). See pictures at end.
SSHing in you can see it's recognised as sdb. I currently only have 1 2TB scratch disk in for testing.
root@MediaMaster:~# lsblk
NAME      MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
sda         8:0    0   1.8T  0 disk
├─sda1      8:1    0     4G  0 part
│ └─md0     9:0    0     4G  0 raid1 /
├─sda2      8:2    0   512M  0 part
│ └─md1     9:1    0 511.4M  0 raid1 [SWAP]
└─sda3      8:3    0   1.8T  0 part
  └─md127   9:127  0   1.8T  0 raid1 /data
sdb         8:16   0 111.8G  0 disk
So I then did the following. Please note I am in no way a linux expert and there is some guesswork here.... if I've done something wrong please tell me!! It does seem to work though!!
I hope this is helpful. Always grateful for feedback.
Andy
root@MediaMaster:~# sgdisk -p /dev/sda
Disk /dev/sda: 3907029168 sectors, 1.8 TiB
Model: ST2000DM001-1CH1
Sector size (logical/physical): 512/4096 bytes
Disk identifier (GUID): ADF28647-D80F-4CCC-A198-687D3F12D704
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 64-sector boundaries
Total free space is 4093 sectors (2.0 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1              64         8388671   4.0 GiB     FD00
   2         8388672         9437247   512.0 MiB   FD00
   3         9437248      3907025071   1.8 TiB     FD00
root@MediaMaster:~# sgdisk -a 64 -n 1:64:8388671 -t 1:FD00 /dev/sdb
Creating new GPT entries in memory.
The operation has completed successfully.
root@MediaMaster:~# sgdisk -a 64 -n 2:8388672:9437247 -t 2:FD00 /dev/sdb
root@MediaMaster:~# sgdisk -p /dev/sdb
Disk /dev/sdb: 234441648 sectors, 111.8 GiB
Model: TS120GMTS420S
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): D67DA5F5-04E3-43CB-A67E-76F2F5B281F4
First usable sector is 34, last usable sector is 234441614
Total free space is 225004397 sectors (107.3 GiB)
root@MediaMaster:~# cat /proc/mdstat
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid1 sda3[0]
      1948662784 blocks super 1.2 [1/1] [U]
md1 : active raid1 sda2[0]
      523712 blocks super 1.2 [1/1] [U]
md0 : active raid1 sda1[0]
      4190208 blocks super 1.2 [1/1] [U]
unused devices: <none>
├─sdb1      8:17   0     4G  0 part
└─sdb2      8:18   0   512M  0 part
root@MediaMaster:~# mdadm --manage /dev/md0 --add /dev/sdb1
mdadm: added /dev/sdb1
root@MediaMaster:~# mdadm --manage /dev/md1 --add /dev/sdb2
mdadm: added /dev/sdb2
md1 : active raid1 sdb2[1](S) sda2[0]
md0 : active raid1 sdb1[1](S) sda1[0]
root@MediaMaster:~# mdadm --grow /dev/md0 --raid-devices=2
raid_disks for /dev/md0 set to 2
root@MediaMaster:~# mdadm --grow /dev/md1 --raid-devices=2
raid_disks for /dev/md1 set to 2
md1 : active raid1 sdb2[1] sda2[0]
      523712 blocks super 1.2 [2/1] [U_]
      [===>.................]  recovery = 17.2% (90112/523712) finish=0.2min speed=30037K/sec
md0 : active raid1 sdb1[1] sda1[0]
      4190208 blocks super 1.2 [2/1] [U_]
      [==>..................]  recovery = 14.3% (600512/4190208) finish=0.5min speed=100085K/sec
      523712 blocks super 1.2 [2/2] [UU]
      4190208 blocks super 1.2 [2/2] [UU]
root@MediaMaster:~# echo writemostly > /sys/block/md0/md/dev-sda1/state
root@MediaMaster:~# echo writemostly > /sys/block/md1/md/dev-sda2/state
md1 : active raid1 sdb2[1] sda2[0](W)
md0 : active raid1 sdb1[1] sda1[0](W)
  • I guess one question I have would be:
    Ideally an SSD should be partitioned on 2048 sector boundry and this was the sgdisk default. I overrode it to 64 sectors to mirror the original partitions exactly. Is this necessary?? Or as long as they are the same size in sectors does thte starting sector matter??
    • Sandshark's avatar
      Sandshark
      Sensei
      When creating volumes on a drive that the GUI cannot see, it is best to use the Netgear utility volume_util (aka rnutil volume_util), not do everything manually.  volume_util --help will point you in the right direction.  Once the volume is created, the GUI should see it, and everything else can be done from there.
      Note that this is for devices the GUI is not designed to see, such as the M2 SSD here or a drive in a non-Netgear external SAS chassis (on compatible rack mount systems), not for a drive that simply fails to show up when it should.
  • Thank you for the nice photos of the RN528X motherboard!
    I see now how it differs from the 6-bay RN526X - the PCI-style connectors for the HDD backplane are longer, allowing for more SATA lanes.
    I'm still curious though, what controller is used for the 2 extra disks? The D-1508 has only 6 built-in SATA channels. And the extra Marvel 88SE9170 chip on the motherboard (at least that's what my RN526X has) provides only 2 extra SATA channels - one for the M.2 and one for the eSATA connector on the back.
    Is it possible that the 8-disk RN528X has a different Marvel chip? Can you post the output of
    lspci|grep SATA
    Also, it might be instructive to see the output of `lsscsi`. Here's for example mine, with 5 bays occupied with 4TB WDs, an M.2 SSD in the slot on the back, and an external Seagate USB-enclosure:
    root@RN526X:~# lsscsi
    [0:0:0:0]    disk    ATA      WDC WD4000FYYZ-0 1K03  /dev/sda
    [1:0:0:0]    disk    ATA      WDC WD4000FYYZ-0 1K03  /dev/sdb
    [2:0:0:0]    disk    ATA      WDC WD4000FYYZ-0 1K03  /dev/sdc
    [3:0:0:0]    disk    ATA      WDC WD4000FYYZ-0 1K03  /dev/sdd
    [4:0:0:0]    disk    ATA      WDC WD4000FYYZ-0 1K03  /dev/sde
    [10:0:0:0]   disk    ATA      TS128GMTS400SE2  5L5   /dev/sdf
    [13:0:0:0]   disk    Seagate  Backup+ Hub BK   D781  /dev/sdg
    • powellandy1's avatar
      powellandy1
      Virtuoso
      Hi
      root@MediaMaster:~# lspci|grep SATA
      00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
      05:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
      06:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
      09:00.0 SATA controller: Marvell Technology Group Ltd. Device 9170 (rev 13)
      and
      root@MediaMaster:~# lsscsi
      [0:0:0:0]    disk    ATA      WDC WD140EMFZ-11 0A81  /dev/sda
      [1:0:0:0]    disk    ATA      WDC WD140EMFZ-11 0A81  /dev/sdb
      [2:0:0:0]    disk    ATA      WDC WD140EMFZ-11 0A81  /dev/sdc
      [3:0:0:0]    disk    ATA      WDC WD140EMFZ-11 0A81  /dev/sdd
      [4:0:0:0]    disk    ATA      WDC WD140EDFZ-11 0A81  /dev/sde
      [5:0:0:0]    disk    ATA      WDC WD140EDFZ-11 0A81  /dev/sdf
      [6:0:0:0]    disk    ATA      WDC WD140EMFZ-11 0A81  /dev/sdg
      [10:0:0:0]   disk    ATA      TS120GMTS420S    9A0   /dev/sdh
      Cheers
      A
      • spiperov's avatar
        spiperov
        Guide
        Hmmm... This is interesting - from your lsscsi output one might conclude that you have 7 disks connected to the 6-channel SATA controller that's built into the D-1508 CPU. Which - if true - implies the presense of a SATA switch (on the HDD backplane?).
        Maybe if you also post the output of 'ls -al /sys/block/sd*' ?
        Here's my output for reference:
        root@RN526X:/data/tmp# ls -al /sys/block/sd*
        lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda
        lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sdb -> ../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0/block/sdb
        lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sdc -> ../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0/block/sdc
        lrwxrwxrwx 1 root root 0 Jan 13 02:05 /sys/block/sdd -> ../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0/block/sdd
        lrwxrwxrwx 1 root root 0 Jan 13 02:07 /sys/block/sde -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sde
        lrwxrwxrwx 1 root root 0 Jan 13 02:07 /sys/block/sdf -> ../devices/pci0000:00/0000:00:1c.0/0000:05:00.0/ata11/host10/target10:0:0/10:0:0:0/block/sdf
        lrwxrwxrwx 1 root root 0 Jan 31 14:18 /sys/block/sdg -> ../devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.1/3-2.1:1.0/host13/target13:0:0/13:0:0:0/block/sdg
ProSupport for Business
