aris1234
Dec 20, 2018Aspirant
Adding a disk to an old Sparc ReadyNAS NV+
I have an old NV+ (Sparc) running Raidator 4.1.14. I've had two Seagate ST2000DM001's running in XRAID for some time and decided to add a 3rd disk for more space and added redundancy. The new disk ...
Dec 20, 2018Guru - Experienced User
Three (or four) disks would switch to from RAID-1 to RAID-5. That will increase space, but it won't add more redundancy.
aris1234 wrote:
not quite the same geometry as the old disk as the old ones are 1859 GB and the new one 1860 GB.
The new one is slightly larger though, so that should be ok. If the new disk were smaller, it would be a problem.
There's some old advice here you could try:
https://web.archive.org/web/20160410141326/http://home.bott.ca/webserver/?p=550 wrote:
Login to Frontview and check to see if any apply and temporarily change the setting to what is listed below.
- Frontview > System > Performance > Enable Journaling
- Frontview > System > Power > Disable disk spin-down
- Frontview > Volumes > Volume Settings > Snapshot > Delete any active snapshots & turn off snapshot schedule
After changing the settings go into Frontview > System > Shutdown > Check and Fix Quotas on next boot and expansion should begin.
You might not see the snapshot settings bit with your firmware - if that's the case just skip that one.
If that fails, you could try removing the new disk and reinserting it (with the system running). If all else fails you can do a factory reset with all disks in place, and then restore the data from backup.
- aris1234Dec 20, 2018Aspirant
Ha - was as simple as a reboot. Who would have thought? :)
After quite a few hours of synching - all working. For those looking to replace Seagate ST2000DM001, the Seagate 2 TB IronWolf 3.5 Inch 5900 RPM Internal Hard Drive seems to work OK.
Should I be concerned with the rotational speed mismatch? bararcuda were 7200 and this is 5900.I'm not looking for performance here - this is purely archival.
