Kallestropp
Jan 31, 2017Aspirant
Adding a drive readynas duo v2
I have been using my duo v2 for a long time now with a wd 2tb green,and today i wanted to add a wd 2tb red.In raidar both drives are green but when i go to admin page it says X-RAID2(REDUNDANT) and o...
Kallestropp
Yes raidar gives green,i wrote that in my first post..so if i do a reset it will be ok?
Jan 31, 2017Guru - Experienced User
If you are switching to flexraid anyway, then there's no reason to diagnose this issue.
I do recommend JBOD mode (two volumes, one for each disk).
A single 4 TB volume is possible, but fragile. If either disk fails, you lose everything. So it is even more important to maintain good backups if you use that.
