Kallestropp
Jan 31, 2017Aspirant
Adding a drive readynas duo v2
I have been using my duo v2 for a long time now with a wd 2tb green,and today i wanted to add a wd 2tb red.In raidar both drives are green but when i go to admin page it says X-RAID2(REDUNDANT) and o...
Kallestropp
Can you point in the direction to do the two volumes
Jan 31, 2017Guru - Experienced User
Again, I don't own a v2, though I do have 4.1.x, 4.2.x, and 6. NAS.
What I suggest is starting with just one disk installed, and then selecting JBOD if it is available or RAID-0 if it is not. Starting with one disk ensures that the NAS can't create a 2-disk volume.
After setup, add the second disk. There will be a way to create a second volume using it.
