Ubbe
Nov 17, 2016Aspirant
Adding disks
Hello.
I just bought a RN214 and 2*6TB WD red.
My question is if i want to add a disk later on will it swapp from raid 1 to raid 5 without deleting any files?
//Joakim
Hello Ubbe,
The NAS should be configured as XRAID if you are planning to add disks.
Adding to an existing XRAID will automatically expand the volume and also adjust the RAID level. Please see How do I horizontally expand an X-RAID 2 volume on my ReadyNAS OS 6 storage system? article.
Welcome to the community!
- JennCNETGEAR Employee Retired
Hello Ubbe,
- UbbeAspirant
Hi JennC.
Thanks for the information and sorry for the late reply.
Regards
Ubbe
- FramerVNETGEAR Employee Retired
Hello Ubbe,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
