MCEComputers
Jul 18, 2022Apprentice
Adding more capacity to existing volume
I have a RNDP-6000 running 6.10.7 with two 12tb drives in X-Raid (Raid 1). I have a couple of 8tb drives I would like to use in this NAS. I know that I would have to destroy the current volume, add t...
Jul 18, 2022Guru - Experienced User
MCEComputers wrote:
My question is, if I create a new single volume now using 2x12tb and 2x8tb drives, can I then add the additional two 8tb drives to that volume once I get them,
That's a good question - I think the answer is yes, though I have not tried it myself.
One option is to switch to flexraid, and add in the 2x8TB you already have as a second RAID-1 volume. Then destroy the volume and recreate when you get the remaining two 8 TB drives.
