MiC_U
May 22, 2019Aspirant
Addinn more drive space for my ReadyNAS 2304
Hello,
i am new here. i am trying to understand more about this NAS 2304.
I want to know if i add a new drive to the empty bay , will the ReadyNAS 2304 automaticlly Add the extra drive space?...
MiC_U
Stephen B
Bay 1 is 3TB
Bay 2 is 6 TB
Bay 3 None Yet *after i put a 2tb then discover the drive is bad soi removed.
Bay 4 is 4 TB just added
i thought i can mix drives, no drive size order matter , right ?
i am thinking to get all 4tb or 6tb. i will do what you said, and upload a snap shot.
one more questions. if i insert 3 drives for now and add one more dirve later. would the system automatic increase the drive space itself?
thanks you !
May 23, 2019Guru - Experienced User
No, the order you add them does matter. If you had inserted 3 TB, then 4TB, then 6 TB you'd have ended up with a 7 TB volume (~6.3 TiB shown on the volume page). But 3 TB, 6 TB, then 4 TB gives you a 6 TB volume (5.45 TiB).
The general rules for adding a disk with XRAID is that it either
- needs to be bigger than any other drive in the array (> 6 TB if you are at 3 TB + 6 TB) or
- exactly match a disk size that's already in the array (3 TB or 6 TB if you are at 3 TB + 6TB)
In your case, your 4 TB drive is being treated as if it's a 3 TB drive (a consequence of violating the rules above when you added it). There's no point in trying to add a 2 TB drive (even if it were healthy) - the system can't add it because it's smaller than smallest drive in your array. The reasons for these limitations are a bit complicated.
But if you follow the two rules above you should always be ok. If you can't follow them, to get the full space you need to destroy the volume and create a new one with all disks in place (which is what the factory default does).
Also, if you follow those rules, then your volume capacity is computed by summing all the disk sizes, and then subtracting the largest.
- MiC_UMay 25, 2019Aspirant
Here is what i have updated my drives. is everything ok now ? if one of the drive fails .. i would just replace it with same size drive or bigger the let it rebuild itself?
PLEASE SEE THE ATTACMENT PICTURES
- StephenBMay 26, 2019Guru - Experienced User
This looks good. 4x4TB -> 12 TB volume (shown as ~10.9 TiB by the web ui).
Correct. You'd replace it with 4 TB or larger.
Note that if you want a bigger volume you need to replace two drives. The capacity rule is "sum the drives and subtract the largest".
Also, keep in mind that RAID isn't enough to keep your data safe. So I do recommend putting a backup plan in place. Also, it is a good idea to get a UPS for the NAS.
- MiC_UMay 26, 2019Aspirant
thanks you Stephen!!!
you said : Also, keep in mind that RAID isn't enough to keep your data safe. So I do recommend putting a backup plan
which raid is good for my setup since i have 4x4tb 12tb.
the reason i pick raid 5, cause the nas server picture show it has little better load performance with Redundancy . what raid would you recommand? since i haven't really start moving files to the nas. i want to set it right for me. *
thanks for your input
