ToddeSwe's avatar
Sep 01, 2021
Admin settings keeps loading over and over again with the latest firmware.
Hi   Having some strange things happening here. I reinstalled my OS on my ReadyNAS 102 yesterday and today when i was trying to go to settings i couldn't use my default password. Installed AVAST to...
  • StephenB's avatar
    Sep 06, 2021
    ToddeSwe wrote:
    The use of the system volume root is 95%. This condition does not usually occur under normal conditions. Contact technical support.
    This is the OS partition ("system volume root").  It's not about how much data you have stored on the NAS.  The full OS partition might be linked to the difficulty in getting the hotfix installed.
    There are three ways to fix this:
    1. Engage paid Netgear support to do it for you remotely.  This will require purchase of a support contract.
    2. Backup all your data, do a factory default, and set the NAS up again.
    3. Fix it yourself with ssh.
    Since you really don't have much data on the NAS, option 2 is what I'd suggest. If you have no experience with the linux command line, I don't recommend option 3.
ProSupport for Business
