ToddeSwe
Sep 01, 2021Guide
Admin settings keeps loading over and over again with the latest firmware.
Hi Having some strange things happening here. I reinstalled my OS on my ReadyNAS 102 yesterday and today when i was trying to go to settings i couldn't use my default password. Installed AVAST to...
- Sep 06, 2021
ToddeSwe wrote:
The use of the system volume root is 95%. This condition does not usually occur under normal conditions. Contact technical support.
This is the OS partition ("system volume root"). It's not about how much data you have stored on the NAS. The full OS partition might be linked to the difficulty in getting the hotfix installed.
There are three ways to fix this:
- Engage paid Netgear support to do it for you remotely. This will require purchase of a support contract.
- Backup all your data, do a factory default, and set the NAS up again.
- Fix it yourself with ssh.
Since you really don't have much data on the NAS, option 2 is what I'd suggest. If you have no experience with the linux command line, I don't recommend option 3.
ToddeSwe
Sep 01, 2021Guide
Yes at first but today I have changed the password because avast complained about the security of my system. I’ve also cleared the browser cache.
Now when I came in to the computer the admin settings page was loaded and steady.
Restarting the computer and see if it works.
Nope it keeps loading over and over again.
Sep 01, 2021Guru - Experienced User
Does it work properly if you disable AVAST?
- ToddeSweSep 01, 2021Guide
No it's the problem is still there after disabled AVAST.
- StephenBSep 01, 2021Guru - Experienced User
What firmware are you running on the NAS? There was a login loop in 6.10.5 that was recently addressed in a hotfix pushed by Netgear.
If you aren't sure what you are running, RAIDar should be able to tell you. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- ToddeSweSep 01, 2021GuideYes it’s that version.
Unfortunately I can’t check for updates because the page is reloaded before that updatecheck is made.
