enkiusz
Aug 28, 2021Follower
Admin UI unusable due to periodic readynasd
Hi,
I am having problems accessing the Admin web UI of the RN3138 running ReadyOS 6.10.5. The admin UI page shows the "ReadyNAS Admin Page is offline" message. I have managed to look into the systemd journal logs and noticed that the readynasd service seems to be periodically crashing and restarting itself due to a segmentation fault in the 'enclosure_monit' process. This manifests with the following error message:
Aug 28 23:02:15 storage1 kernel: enclosure_monit[749]: segfault at 7f4a17f3ddb0 ip 00000000004bde23 sp 00007f4a15a3b430 error 6 in readynasd[400000+17b000]
The above causes readynasd systemd unit to fail and be restarted:
Aug 28 23:02:15 storage1 systemd[1]: readynasd.service: Main process exited, code=killed, status=11/SEGV
Aug 28 23:02:15 storage1 systemd[1]: Failed to start ReadyNAS System Daemon.
Aug 28 23:02:15 storage1 systemd[1]: readynasd.service: Unit entered failed state.
Aug 28 23:02:15 storage1 systemd[1]: readynasd.service: Failed with result 'signal'.
Aug 28 23:02:16 storage1 systemd[1]: readynasd.service: Service hold-off time over, scheduling restart.
Aug 28 23:02:16 storage1 systemd[1]: systemd-journald-audit.socket: Cannot add dependency job, ignoring: Unit systemd-journald-audit.socket is masked.
Aug 28 23:02:16 storage1 systemd[1]: Stopped ReadyNAS System Daemon.
Aug 28 23:02:16 storage1 systemd[1]: Starting ReadyNAS System Daemon...
Aug 28 23:02:16 storage1 readynasd[781]: readynasd log started
Aug 28 23:02:16 storage1 readynasd[781]: readynasd started. (restarted=0)
Aug 28 23:02:16 storage1 readynasd[781]: DB (main) schema version: 24 ==> 24
Aug 28 23:02:16 storage1 readynasd[781]: DB (queue) schema version: new ==> 0
Aug 28 23:02:17 storage1 apache2[22230]: [cgi:error] [pid 22230] [client 10.10.10.6:33052] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://storage1.shill.gq/admin/
Aug 28 23:02:20 storage1 apache2[22469]: [cgi:error] [pid 22469] [client 10.10.10.6:33064] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://storage1.shill.gq/admin/
Aug 28 23:02:20 storage1 apache2[22529]: [cgi:error] [pid 22529] [client 10.10.10.6:33066] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://storage1.shill.gq/admin/
Aug 28 23:02:21 storage1 systemd[1]: Reloading.
Aug 28 23:02:22 storage1 connmand[3132]: ntp: adjust (slew): -0.005129 sec
Aug 28 23:02:22 storage1 apache2[29292]: [cgi:error] [pid 29292] [client 10.10.10.6:33068] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://storage1.shill.gq/admin/
Aug 28 23:02:22 storage1 systemd[1]: Reloading.
Aug 28 23:02:23 storage1 readynasd[781]: Last run started at 1630184534 was aborted
Aug 28 23:02:23 storage1 readynasd[781]: Detect abnormal shutdown of readynasd and child. (enclosure_monit)
Aug 28 23:02:23 storage1 readynasd[781]: ReadyNASOS service or process (enclosure_monit) was restarted.
Aug 28 23:02:25 storage1 apache2[22246]: [cgi:error] [pid 22246] [client 10.10.10.6:33070] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://storage1.shill.gq/admin/
Aug 28 23:02:25 storage1 readynasd[781]: Using fan mode: balanced
Aug 28 23:02:25 storage1 kernel: enclosure_monit[924]: segfault at 7f6f93189230 ip 00000000004bde23 sp 00007f6f90b43430
Only to again terminate after a few seconds. This problem persists for a number of minutes and (at least now) the UI is back working. There is however clearly something wrong here. And this issue is very annoying.
