john_h1
Aug 29, 2016Tutor
Advice on replacing ReadNAS Pro 6 with 2x 4 Bay ReadyNAS boxes.
I have a ReadyNAS Pro 6 with 6 x 3TB drives in Raid X which I think gave me 12TB of usable storage. My ReadyNAS recently suffered some sort of corruption that made the volume inaccessible. This h...
mdgm-ntgr
Aug 29, 2016NETGEAR Employee Retired
The limitation where we used the capacity of the smallest disk was for X-RAID on our legacy Sparc boxes. We discontinued the last of those several years ago now.
On newer boxes than that we use X-RAID2. With the default single-redundancy (uses RAID-5 with three or more disks) you would get the capacity of your drives summed minus the capacity of the largest disk minus some overheads.
With X-RAID2 dual-redundancy (uses RAID-6 and thus requires a minimum of four disks) you would be limited to the capacity of the 4th largest disk (as a RAID-6 layer requires a minimum of four disks)
john_h1
Aug 30, 2016Tutor
Thanks guys.
If I have two boxes then I think RAID 5 with single redundancy will provide enough protection and provide for my incremental upgrade to bigger disks.
- StephenBAug 30, 2016Guru - Experienced User
As mdgm says, the capacity rule is "sum the drives and subtract the largest". 6x3TB with default XRAID would give you a 15 TB volume. The Pro-6 reports that as 13 TiB (but it uses a TB label, which is confusing). (1 TiB = 1024*1024*1024*1024 bytes, 1 TB = 1000*1000*1000*1000 bytes).
-You might consider starting with 3x4TB instead (if that leaves you enough free space). That costs about the same, and gives you an expansion slot for later.
-OS 6.6.0 has an interesting new backup method you might look into - that would require two RN314 though.
I recommend getting NAS-purposed disks (WDC Reds, Seagate VNs), or enterprise. I don't recommend desktop drives.
- john_h1Aug 30, 2016Tutor
My plan is to reuse my current disks to cut down the initial costs. I have 1 spare 3TB disk plus the 6 in my Pro, so I was planning to add 1 4TB to the main box to start with.
That works, though 1 TB of the drive will be unused until a second 4 TB is installed (4x3TB and 4TB+3x3TB both give you a 9 TB volume).
