paikinator_yaho
Mar 27, 2012Aspirant
AEBS: Bad Packets Unrecovered TCP Retransmits NV and NV+
Bad Packets Unrecovered TCP Retransmits TCP Retransmits w ReadyNAS NV NV+ and Airport Extreme Base Station 5th Generation I got an Airport Extreme Base Station (AEBS), 5th generation this past Nove...
paikinator_yaho
Mar 29, 2012Aspirant
All of my network via static assigned IP's works on the Procurve.
All of my network isolated on the AEBS induces lots errors. I am not sure why this is.
Also… when I have my network all on the Procurve and I wire it to the AEBS via cat6a I get errors if the AEBS uses DHCP to assign addresses to my network devices on the procurve. This is what I want the AEBS to do so it is a problem for me. I don't know why the AEBS would cause errors when it is wired to my network on the procurve. Baffling.
Another person has told be that there AEBS does not give them errors with their ReadyNAS's attached to it. I am trying to understand if there is some setting or thing I can do to eliminate the errors or is this AEBS just a lemon.
Currently I can't wire the procurve together with the AEBS. I can only get to the AEBS by sharing my connection via the wireless-n from my main computer.
The info on the jumbo frames is great … thanks.
Normally I run my video_TS folders onto my main computer from my movie NAS and pipe the results to my HDTV.
But I suppose once I jailbreak it and try to do a similar thing with my Apple TV there will be a problem.
I will probably have to set Jumbo Frames to off.
