paikinator_yaho
Mar 27, 2012Aspirant
AEBS: Bad Packets Unrecovered TCP Retransmits NV and NV+
Bad Packets Unrecovered TCP Retransmits TCP Retransmits w ReadyNAS NV NV+ and Airport Extreme Base Station 5th Generation I got an Airport Extreme Base Station (AEBS), 5th generation this past Nove...
Mar 29, 2012Guru - Experienced User
I think this is an important clue. Maybe try different cables, or using a different switch port on both devices. This should work, the fact that it fails suggests something is either broken in the switch or the router, or there is an incompability.
paikinator@yahoo.com wrote: … when I have my network all on the Procurve and I wire it to the AEBS via cat6a I get errors if the AEBS uses DHCP to assign addresses to my network devices on the procurve. This is what I want the AEBS to do so it is a problem for me. I don't know why the AEBS would cause errors when it is wired to my network on the procurve. Baffling…
I would also look at the ethernet configuration for the switch port in the AEBS. Perhaps as an experiment set it manually to 100 mbits, and see if it works better.
