paikinator_yaho
Mar 27, 2012Aspirant
AEBS: Bad Packets Unrecovered TCP Retransmits NV and NV+
Bad Packets Unrecovered TCP Retransmits TCP Retransmits w ReadyNAS NV NV+ and Airport Extreme Base Station 5th Generation I got an Airport Extreme Base Station (AEBS), 5th generation this past Nove...
May 06, 2012Guru - Experienced User
Thanks for the update. Although annoying (and hard to track down), replacing the cables is inexpensive. You might contact the seller, even if you don't have the packaging and are beyond the return period.
