paikinator_yaho
Mar 27, 2012Aspirant
AEBS: Bad Packets Unrecovered TCP Retransmits NV and NV+
Bad Packets Unrecovered TCP Retransmits TCP Retransmits w ReadyNAS NV NV+ and Airport Extreme Base Station 5th Generation I got an Airport Extreme Base Station (AEBS), 5th generation this past Nove...
May 11, 2012Guru - Experienced User
A loop is a circular path, so it can only happen with devices that have multiple ethernet connections. For instance if you have two ethernet cables between the switch and the router.
