paikinator_yaho
Mar 27, 2012Aspirant
AEBS: Bad Packets Unrecovered TCP Retransmits NV and NV+
Bad Packets Unrecovered TCP Retransmits TCP Retransmits w ReadyNAS NV NV+ and Airport Extreme Base Station 5th Generation I got an Airport Extreme Base Station (AEBS), 5th generation this past Nove...
paikinator_yaho
May 11, 2012Aspirant
Ah... I asked the tech and he said as much, but then he seemed to think that the likely culprit is my NAS devices????
They don't seem to have the issue when direct connected to my Mac, but I would probably need to dump a bunch of stuff on them to max them out.
Last time when I tested them I dumped a 13 gig folder on each of them and didn't experience any errors, and I played some media files and dumped big files on them to see if I could cause a choke, but didn't have a problem.
Could there be a problem with the 2 NAS devices running on the same switch? I wouldn't think so since they both have separate static IP's
Anyhow HP is sending me a new switch except they didn't have any of the 1410 8G's on hand so they are shipping me an 1800 8G which is a managed switch.
Hopefully, this will do the trick and my error issues will be solved.
