Griff_EWP
Oct 07, 2016Aspirant
After update to 6.6.0, can't access anything on Admin page
After updating my ReadyNAS 2100 from firmware 6.5.1 to 6.6.0 this morning, I can no loger access anything on the admin page. IF I can get the admin page to load after login, the page is blank. If I c...
- Oct 10, 2016
Hi guys, just an update here. The issue I had after the 6.6.0 update turned out to be a permissions issue with the ReadyNAS users. Apparently there were some orphaned accounts (ui's as the tech called them) created by the ReadyNAS OS (which I still don't understand how), but 2 1/2 hours with support fixed the issue. Just as a side note, I had the exact same issue on the same device when I did the update to 6.5.1 some time back. Again, support fixed that issue as well, so I'm still confused as to how this could happen again when no changes have been made since the last firmware update. Wish I could give a little more info on this, but the technician closed the chat log before I got a chance to copy it for my records. Thanks to all who posted replys to this thread.
guifort
Hello,
Not a solution for your problem but I get the same issue on RN202 upgraded to 6.6.0.
I access to the webinterface with HTTPS I can access to the dashboard but the webinterface stop few second after.
I have SSH enable but I didn't find usefull information in the logs.
- mdgm-ntgrOct 07, 2016NETGEAR Employee Retired
Download the logs using RAIDar 6.1 and then send them in (see the Sending Logs link in my sig) please.
- NaplavaOct 08, 2016Aspirant
Hi,
Have the same problem. Sending logs. Thanks for you help.
Pavel N.
- guifortOct 15, 2016Aspirant
Hello
I just fix this issue after a factory reset but It "re come" few time after.
I find the root cause : it come from my "Shared Righ"
When you modify the share right from WIndows (With Active Directory) the Webinterface crash.
I didn't know why...
Regards
