Griff_EWP
Oct 07, 2016Aspirant
After update to 6.6.0, can't access anything on Admin page
After updating my ReadyNAS 2100 from firmware 6.5.1 to 6.6.0 this morning, I can no loger access anything on the admin page. IF I can get the admin page to load after login, the page is blank. If I c...
- Oct 10, 2016
Hi guys, just an update here. The issue I had after the 6.6.0 update turned out to be a permissions issue with the ReadyNAS users. Apparently there were some orphaned accounts (ui's as the tech called them) created by the ReadyNAS OS (which I still don't understand how), but 2 1/2 hours with support fixed the issue. Just as a side note, I had the exact same issue on the same device when I did the update to 6.5.1 some time back. Again, support fixed that issue as well, so I'm still confused as to how this could happen again when no changes have been made since the last firmware update. Wish I could give a little more info on this, but the technician closed the chat log before I got a chance to copy it for my records. Thanks to all who posted replys to this thread.
THE_BLOB
Oct 10, 2016Aspirant
I have the same problem on RN104 16TB, I cannot access admin page after 6.6.0.
I have read that taking out drives and lableing them then rebboting with another scratch drive and doing afactory reset may solve the problem but I think if the drives were put back in wouldn't they just revert back to the operating system that is on them. I am not sure if it would wipe all the disks and reformat. I also do not have SSH turned on, although I can access the shares.
Any one any ideas?
Thanks
Oct 10, 2016Guru - Experienced User
What firmware were you running before the update?
- Griff_EWPOct 10, 2016Aspirant
