andrij
Jan 12, 2019Aspirant
After upgrade Transmission addon doesn't work
Hi,
I changed hard drives in my NAS storage, now I have two hdds in this default flexible raid. The problem is before upgrade Tramission was working properly, and after upgrade the site open an...
- Jan 12, 2019
Can you check that the system can reach the internet? One way to do that is to download the log zip file, and search for NTP - which syncs the time on the NAS with an internet time server.
Also, if you use port forwarding in your router, you should make sure it is forwarding to the correct IP address - that might have changed when you did the factory reset.
Jan 12, 2019Guru - Experienced User
andrij
Thank you very much! I haven't thought even that device may not had internet, and I had manual settings and IP address was ok but somehow default gateway ip dissapered and that was the reason. Thank again.
