Hank1974
Sep 01, 2016Aspirant
Alerts: Add Button is missing - Can only send alerts to one person #27358988
I just purchased a ReadyNAS 202 for our company (firmware 6.3.4).
I have alerts working (would only work with DHCP, never with Static IPs - which sucks because we can't use the FQDN to connect via ...
Hank1974
Sep 06, 2016Aspirant
I tried uploading the ARM file in both .zip and .img format and both failed.
There's no error message as the wheel just continously spins forever.
Regarding my IP configurations, I use the same DNS IP's for both static and DHCP. HTTP and HTTPS are also green and configured properly.
BrianL2
Sep 07, 2016NETGEAR Employee Retired
Hi Hank1974,
I've sent you a PM. Kindly check your inbox.
Kind regards,
BrianL
NETGEAR Community Team
