Retired_Member
Jan 13, 2014Am I wise to Upgrade ?
At present I have a Duo v2 with 2x WD Red 2TB Discs, Its running OK streaming Music, Movies etc to my Android devices, S$ phone, Galaxy note 10.1 tablet using the Asus iCloud App with my router. Ready...
xeltros
Jan 14, 2014Apprentice
A test doesn't harm anyway, I suggest you to test the interface with the VM and to make up your mind.
http://apps.readynas.com/pages/?page_id=143
You will be able to test the functionalities, the interface, I haven't tested ready cloud on the VM but should work too.
Ready cloud is not as flexible as dropbox is. You can't share a specific folder for example. I believe you can connect to ready drop from only one location at a time.
So just check out, see if that fits your needs and if you get positive updates on the forum consider buying. If that doesn't answer your needs then just try another brand.
