chathams
Jun 19, 2020Aspirant
Amazon Drive Cloud link stopped working
Amazon Cloud link stopped working. It worked for a few years, then as I updated my ReadyNAS and wanted to point the Amazon Cloud to a new directory I discovered it stopped backing up. I believ...
- Jun 19, 2020
Hi chathams,
Have you tried leaving then rejoining the ReadyNAS to Amazon Drive?
You can also download the system logs of your NAS then check the amazon-drive.log to see what might have caused the issue.
JohnCM_S
Jun 19, 2020NETGEAR Employee Retired
Hi chathams,
- chathamsJun 19, 2020Aspirant
Apparently I needed to click on the root directory and change that path, not attempt to add another.
Thanks for your help.
