chathams's avatar
chathams
Amazon Drive Cloud link stopped working
Amazon Cloud link stopped working.    It worked for a few years, then as I updated my ReadyNAS and wanted to point the Amazon Cloud to a new directory I discovered it stopped backing up.   I believ...
  • JohnCM_S's avatar
    Jun 19, 2020
    Hi chathams,
    Have you tried leaving then rejoining the ReadyNAS to Amazon Drive?
    You can also download the system logs of your NAS then check the amazon-drive.log to see what might have caused the issue.
ProSupport for Business
