portalman
Sep 24, 2026Luminary
Announcing a new project
Hi folks, I'm working on a new readynas related project. Let me start by saying I love these things. I have a bunch of Pro6 and RN516 particularly, but I've worked on lots of different models. ...
portalman
Sep 29, 2026Luminary
I’ve now begun to start design on a bootable usb with a single function - factory reset. To build a Debian 13 install from an image and install my bespoke tools. Let’s see it if I can make it work.
- SandsharkSep 29, 2026Sensei
You may want to look into FAI as a mechanism to do that.
- portalmanSep 29, 2026Luminary
I'm currently looking at a different way. I've used an AI agent to reverse engineer the ReadyNAS flash contents. My plan to is use something similar, but deployed to a USB stick. It will have one 'boot mode' only - factory reset. It will blat the disks, set up partitions and RAID, copy on /boot and / from images, and install grub.
Baby steps at the moment. UI is almost done. Lots of testing to do. And it's all quite high risk stuff.
