delhux
Oct 08, 2010Aspirant
Anybody using a 2TB+ USB Hard Drive for external backup?
I'm interested in finding a 2TB (or larger) external USB HD to use in conjunction with Frontview backup. Curious if anyone can recommend a compatible solution--the official compatibility list for U...
mdgm-ntgr
Jul 05, 2012NETGEAR Employee Retired
Sounds like the GoFlex disk was formatted using GPT. You need to format it with the MBR partitioning scheme.
