dgerson76
Jul 16, 2009Aspirant
Anyone using the new Western Digital WD TV HD Media Player?
This WD TV device lets your watch movies/pics from an external drive, and connects to your HDMI TV. Looks awesome, connects via USB. Great price, about $80. Checking to see if anyone has used thi...
jraneses
Jul 18, 2009Aspirant
ppftong wrote: @jraneses
I have basically the same set up - WDTV running WDLXTV but I can seem to mount the media directory on the ReadyNAS Duo using NFS.
Would appreciate your help in how you config your WDTV and your ReadyNAS Duo.
Many thanks
I'm not currently auto-mounting shares on the Duo, but you can easily do so by editing the net.mounts config file. Any direct mounts you create on the WDTV via ssh are retained between power cycles of the device. Note that turning the WDTV off using the red button the remote doesn't actually power it down, rather it just puts the WDTV into sleep or hibernate mode.
Here's an example using xmount, where nas is the name of the ReadyNAS Duo, media is the name of the share, and duo is the name of the folder that will show up on the WDTV:
xmount nas:/media duo nfs
