paule123
May 20, 2012Aspirant
AP9620 Legacy Communications Smartslot Card?
I have an APC Smart UPS 700 with an empty smart slot. Does anybody know if a ReadyNAS Pro 4 will work with the AP9620 Legacy Communications Smartslot Card? The card comes with a serial and USB port....
paule123
May 26, 2012Aspirant
Just an update: It turns out the AP9584 serial to USB conversion kit is only compatible with Back UPS and Back UPS Pro units. Apparently it does not work with Smart UPS units.
I decided to get an APC Smart UPS SUA750 that comes with a USB port built in. For $100 with new batteries on ebay, I figured that was a sure bet vs. experimenting with a $50 AP9620 USB card that might not work...
