steveoelliott
Jun 23, 2016Luminary
APC Backups Pro 900 with ReadyNAS Pro 6 Buzzing
Hi all,
I have purchased a new UPS (APC Backups Pro 900) to replace my existing old Backups CS-500 on my ReadyNAS Pro 6. I have noticed that when the new BackUPS 900 is running on battery power, the NAS makes a distinctive buzzing noise which is coming from the PSU.
I’ve done some research online and it seems many UPS’s (this one being an APC BackUPS Pro) use something called a stepped sine wave rather than a pure sinewave. Apparently, this can cause PFC power supplies to buzz when running on battery power. Question is, is the buzzing a harmless side effect or is it likely to shorten the life of / damage the PSU???
Oddly, no such buzzing on battery noticed with a BackUPS CS-500 which is ancient!
Thanks...
I don't really know if the buzzing would be a problem, though I've never heard with my cyberpower.
if you have an option to exchange it for a pure sinewave, then perhaps you should. PSUs shouldn't buzz.
- steveoelliottLuminary
I've purchased it now lol... Seems other folks use it without issue but the buzzing concerns me slightly... Need to speak to some folks who know electronics.
