MrAsker
Sep 09, 2012Tutor
APC Smart-UPS SC 420VA 230V (SC420I)
Hi, I have two ReadyNAS NV+ in two different locations (home and summerhouse) and they are both supported by two "APC Back-UPS CS 500 (BK500EI)". Instead of just replacing the old batteries I'v...
PapaBear1
Sep 09, 2012Apprentice
Have you considered seeing if you can find suitable batteries from other sources. There happens to be a battery supply store near me that stocks suitable batteries for my older APC units. When I bought two of my current units some four years ago, it was cheaper buying new units that getting new batteries from APC. (I bought the units at a discount store).
As to the specific units mentioned, I have no personal experience as mine are two 750 watt units (1250VA) and an 865 watt unit (1500VA) unit.
