kartman666
May 02, 2016Aspirant
Apps not showing up now
hi, i have a couple of problems hope you guys could help me with please? I have 2 NAS hard drives 1: 4tb and 1: 3tb Both WD RED. I also Expaned them both so showing has 1 hard drive. Ques...
- May 02, 2016
kartman666 wrote:
It shows both hartd drives BLUE and joined together BUT only showing the smaller hard drive Data and NOT both.
You are confusing the data volume with the disk drives. Please read my previous reply, and if you find it confusing, ask some questions.
There only is one data volume with xraid. And with two drives, the size of that volume has to be the size of the smallest disk.
If you want to give up XRAID redundancy, you can switch to jbod. I sketched out how to do that in the earlier reply.
kartman666
hi,
Apps are now working but not sure what to do with hard drives, still re syncing for now.
what happens after resyncing?
Whast would you do to fix this?
thanks for all your help
much appreciated
Colin
May 02, 2016Guru - Experienced User
- kartman666May 02, 2016Aspirant
Thank You Stephen for all your help..
I finally understood what to do, ive now got 2 hard drives seperated..
Colin
