Geohans's avatar
Geohans
Tutor
Oct 10, 2020
Availability 6-bay replacement for my PRO6
In april 2020 I orderd a RN42600 as a replacement for my PRO6 but nothing is deliverd yet, this takes to long even considering Covid-19. Netgear provides no anwer. Does Netgear still produce this model? or any 6-bay model? Or do I have to change brand?
  • Geohans
    Welcome to the Community!
    Where did you purchase the unit? There's difficulty of getting ReadyNAS units circulated or manufactured due to this current state we are in but if you have purchased the unit that is in stock it should have been delivered and Yes the RN400 series is still an active model.
    Kindly send me a PM regarding the information of your purchase so we can check.
    HTH
1 Reply
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Geohans
    HTH
ProSupport for Business
