BlackCloud
Oct 07, 2013Tutor
Backup - sync functionality
Running OS 6.1.2 on the 102 model. I am setting up backup jobs and I want the destination folder on my ReadyNas to replicate what is happening in my source folder (laptop). I might have understood ...
vandermerwe
Oct 07, 2013Master
If you don't want to setup rsync then yes.
Alternatively you can use backup software on the laptop to backup to the NAS, you can then configure it to do incremental backups with periodic full backups which would achieve what you want.
You can use any backup software for this , but take a look at deltacopy too.
