BlackCloud
Oct 07, 2013Tutor
Backup - sync functionality
Running OS 6.1.2 on the 102 model. I am setting up backup jobs and I want the destination folder on my ReadyNas to replicate what is happening in my source folder (laptop). I might have understood ...
BlackCloud
Oct 08, 2013Tutor
Thanks again! I looked into DeltaCopy and it works a dream - so simple to set up I almost thought I missed something.
Note to others wanting to give DeltaCopy a go: if you are happy to initiate backup from your computer only use the DeltaCopy client (after installation the server window appears, close that one and access the client from the start menu). Also, make sure that your ReadyNAS destination folder has rsync enabled.
