BlackCloud
Oct 07, 2013Tutor
Backup - sync functionality
Running OS 6.1.2 on the 102 model. I am setting up backup jobs and I want the destination folder on my ReadyNas to replicate what is happening in my source folder (laptop). I might have understood ...
BlackCloud
Oct 08, 2013Tutor
Thanks for the comment! I am always a bit hesitant about adding "functionality" that is already in place, but rsync seemed to work fine in my tests.
Unfortunately now my ReadyNAS 102 has packed in, or at least failing to boot (power led rapidly flashing, ACT led constant, disk leds are blank even though disks are spinning). RAIDar find the unit and the disks but cannot access it. Admin login cannot establish connection.
I got a Level 3 ticket with priority 1 logged seven hours ago but still no feedback, not even to the Level 1/2 support that logged the ticket...
Has anyone successfully tried a OS reinstall using only one disk? At this point I am nut trusting that it will not format/corrupt the disks and want to safeguard the redundancy.
Thanks.
Thanks.
