NND's avatar
NND
Backup from Firewire 800 disk to NAS is slow!?
Hi All,   I have RN426, connected to my Mac Pro 5.1. Two days ago I started back up of one of my Firewire 800 disks (WD 2TB). I used Carbon Copy Cloner to back up whole 2TB disk (almost full) to a ...
  • StephenB's avatar
    Aug 03, 2020
    NND wrote:
    I just restarted computer (after two days) and then run Blackmagic Disk Speed Test on that NAS share and got about 99MB/s write and 95 read, that should be good speed?
    Yes, that is what you'd expect for gigabit ethernet.  However, if you copy a lot of small files, the speed will drop.
    Have you compared the drag-drop speed to the mac with your carbon copy cloner?
    Then perhaps also compare drag-drop from the NAS to the firewire drive with the drag-drop from the NAS to the mac hard drive.
ProSupport for Business
